I have a 1983 Oday 30, it has a manual and automatic bilge pump installed. The manual pump is locater just under the stern seat. Both pumps share the same discharge thru-hull, which is locate directly above and very close (about 2") to the exhaust pipe. The discharge hose coming from the automatic pump exits from the back of the quarter birth making a sharp turn upward for about 18 inches or so then loop down to the thru-hull. This seem to be necessary do to the closest of the thru-hull to the waterline. I want to know from other Oday 30 owners if this is the original configuration. The backwash from this layout is probably between 1.5 and 2 gallons. If this was changed in later model 30's please explain?
