O'Day 28 prop question
Mike Lombardy
I have a 1983 O'Day 28 with a Universal 10HP driving a 2 blade prop. I sail in waters with considerable tide currents and often the 10HP is not sufficient to push the boat at anything other than 1/2 knot (it that). Has anyone put on a 3 blade prop? If so, did it meet your needs? What type? Thanks in advance. Mike
Justin - O'day Owners' Web
Prop
Mike - Sounds like you're not getting full engine efficiency. Are you talking about .5 through the water or over the ground? What is your speed over the ground in still water? You speed through the water in currents should obviously be the same, so your ground speed should be water speed less current. Simply changing two bladed to three bladed prop isn't going to be the answer. Either you are using an incorrectly sized prop or you have an engine issue. When you run under power are you getting full revs? Over-revs? You should be proped more or less so that 80 percent throttle gives you hull speed. Check your revs, if they are high either your have too small a prop or something is slipping. If you are reving too low, either you have too big a prop, your throttle cable is not fully opening the throttlebody, or you have an engine problem where the power is low. If you get an underrev, try manually operating the throttle while someone else steers. If this solves the problem you need to adjust, lubricate or replace your throttle cable. If none of these solve the issue you need a compression check. You might want to have this done for you but I would suggest having someone do it while you watch so you learn to do it. This is a good indication of engine health. If the compression is good, next look to fuel delivery. Make sure your lines are not gunked up, kinked, or otherwise damaged and replace your fuel filters. After each step run the engine and see it the problem is resolved. Next, have someone determine that you are getting decent pressure at the injectors. The pump may be failing or your injectors may need cleaning. Only after you have ensured that your engine is in top shape should you mess with the prop. Make sure you have the correct pitch and diameter. If not, change to the correct one. If your engine is working ok and the prop seems to be right, try working with someone to move to a slightly different size to address the issue. Going to a three bladed prop is not the answer. Two to three blade switches are typically done to address power delivery characteristics, not to address power deficiency. A three blade prop will need to be of small pitch or diameter than a two bladed prop so that the load on the engine remains appropriate. You will get more water pushed with the three, good for close quarters and docking manuevers, but you may lose top end. Justin - O'day Owners' Web
K
Kevin
Props
Dear Mike, Thanks for your note. The three blade unit spec for the Oday 28 is a 13” diameter x 10” pitch. I’m not certain of the shaft OD. You will find that as conditions arise your boat speed will not be lost as fast with the three blade. The three blade however may not increase the boats speed when powering through a current. The lack of speed with the two blade may also be caused by the lack of efficiencies it is suffering. You should, with slight differences, achieve in flat calm water equal speeds with the two and three blade. If you would like to e-mail me the conditions which you are seeing the greatest speed loss I will be happy to comment on it. Hope this helps. Kevin
