Oday 28 cradle drawings / dimensions
Bob
I have recently moved to Chicago from Tennessee and for the first time will have to haul out for the winter. Need to have a cradle made. Does anyone have drawings or dimensions for an Oday 28 cradle? I'm very concerned about getting the spacing correct. Have checked with Rudy and the drawings are not in the papers he has from Oday. Also, if anyone knows of a good cradle maker in the Chicago / southern Wisconsin area, please let me know. Greatly appreciate any help. Also, any advice on setting up the cradle to hold the boat for 6 months at a time without deforming the hull will be greatly appreciated. As a southern boater, hauling out for the winter is new to me and I want to make sure I do it right the first time. Thanks, Bob Amos s/v "Simple Dreams"
Bill Coxe
O'Day 28 Cradle
Bob, my manual for my 1979 O28 addresses supporting by poppets, but the guidelines should apply to a cradle as well. First, don't put all the weight on the keel or the hull will distort. The poppet pads should be under bulkheads, berth fronts or pan stringers. The kicker to all this is the last sentence;"A storage cradle designed for this boat is available through your O'Day dealer." If Rudy doesn't know, the knowledge may have ben lost forever. I think common sense will carry you through. Also, the manual recommends disconnecting the prop shaft coupling to avoid bending the shaft. I do believe that there is a question of exactly how stiff this hull is. Hope this helps, but a good yardmaster should be able to fix you up. Bill Coxe, O28 Kukulcan, New London, CT
Mike
cradle
Bob- I have an O'day 28 with a steel cradle. Next time I'm up I'll measure the on-center dimensions for the four posts, the pad sizes, the over all square, and the gauge of the steel used in the construction. also I'll measure the post heights and the screw length for the adjusters. As Bill said a good yard will be able to find or build a cradle for you and if all else fails some yards rent jack stands for the lay up till you can build something. If you post your boat on the O'day site then I will e-mail you the dimensions you seek. I may even be able to get a photo to post of the cradle. Good Luck, Mike
Likes: seanmcclain
Bob
Thank you
Thanks for the responses, guys. Mike, I'm in the Owner's Directory. Select "28" for model and type in Chicago for the city and I'll be the first one on the list. Appreciate the assistance. Thanks again, Bob Amos s/v "Simple Dreams"
Mark
Oday 28 Cradle
Mike, I'm in the same "boat" as Bob is. I've also purchased a 1985 Oday 28 and need cradle dimensions/specs. Do you think you could forward me similar info? -Mark
Mike
info to Mark
Mark- Like Bob, if your boat is on the O'day owners site with your e-mail address I'll be happy to send you the cradle dimensions. I think I need to know the name of your boat and I can find you. Regards, Mike
Mark
Info to Mark
Mike, Boat name is "archimedes"; my last name is "Portelli" let me know if you can't find it; I added it today. Thanks very much again! -Mark
