O'Day 272 rig
81
- - Somerset,
Still need to get a 272 mast or accurate measurements. If you have a 272 that is easily accessable( mast down ,uncovered) or you have trashed a 272 call me. I have a mast from a O'Day 27 but it is too big in all diminensions, plus the 272 uses a mast with aft swept spreaders and single lower shrouds and no Rudy does not have the measurements for this stick. Looking to measure boat in R.I. S.E. Ma., E.Ct.
Thanks,
Ted
bria46
Jan 15, 2011
286
Oday 272 Waukegan, IL, Sarasota, FL
I have an 1986 272. It does NOT have aft spreaders. There are single chain plates, Port and Starboard. My mast is already up. Check with the OEM manu. Z-Spar.
Jun 2, 2004
1,944
Oday Day Sailer Wareham, MA
I think Z-Spar is out of business, but check with Rig Rite (www.RigRite.com) they have parts and I believe entire rigs in stock. They should have the dimensions and specs for the 272. I'm very surprised that Rudy doesn't have this on file...... but then he is definitely THE O'Day "guru", but can't know everything. We all (as owners of various O'DAY Sailboats) serve both as Rudy's customers and sometimes his best source of info.
BTW: Rig-Rite is in Warwick, RI
You could also check out Newport Nautical Supply, they are a marine consignment/surplus store and might have a 272 mast. Marine Consignment of Wickford (RI) is another possiblity. F.L. Tripp & Sons in Westport, MA was a big O'DAY Dealer and might know of a local 272 owner that could help you, ditto for Burr Brothers Boats in Marion, MA.
bria46
Jan 15, 2011
286
Yes, Sunbird is correct. z-spar is now marketing its products thru RigRite. The stuff that I ordered for my Z-Spar Mast, 4 years ago were shipped out of Florida.
measel
Nov 11, 2010
1
Oday 272 Lake Texoma
272 mast length
I've got mine down and it measures 29' 10". It's 15' 3" from the bottom to the center of the spreader. The spreader itself is straight, but the mounts are at a slight angle aft.
Feb 4, 2007
81
- - Somerset,
272 Rig
Thanks, that info is very helpful. I have the original 272 factory manual. It has all the standing dimensions but not the actual spar dimension.
Much appreciated
Ted
Jun 2, 2004
1,944
Dec 27, 2011
279
Oday 272 Pensacola
Where? I went to one oday owners yahoo group and found verylittle...
cbourne200
O'Day 272
Pensacola
Jun 2, 2004
1,944
Try clicking on one of the links that I posted above. It should ask for your YAHOO ID, if you have one, type it in, if not it should guide you through the sign-up.
Apr 8, 2010
1,606
Frers 33 41426 Westport, CT
I think Z-Spar is out of business.
They are NOT out of business, they just don't do business in the USA anymore under that name. They have a subsidiary in florida called US-Spars that the use for North America now. They stock all the same parts, direct interchangability with the OEM Z-Spar rigs.
I ordered a new rigid vang and spinnaker pole from them a year or two ago. Easy to work with, good prices.
Dec 27, 2011
279
Oday 272 Pensacola
Thanks for info. Had a note from moderator of TRUE oday owners group to join group. Downloaded manual fine...
Thanks
Charels
