O'Day 27 shaft seal leak
Jun 14, 2015
30
Oday 30 1110 Lake Grapevine
Have a drip from my shaft seal about 10 to 15 drips per minute is this normal and if not quick fix or replacement
Jan 27, 2008
3,086
ODay 35 Beaufort, NC
You should be able to loosen the locknut on the stuffing box and then tighten the stuffing box to slow down the drip rate. Too tight will cause the shaft to get hot and maybe score it. Too loose can sink your boat, make it just right.
Jan 27, 2008
3,086
With the engine running and the shaft turning it should drip one to two drips per minute. This is "just right." So SHUT OFF THE ENGINE then do the following:
loosen the locknut with a packing nut wrench, then tighten the stuffing box to compress the stuffing to slow the drip rate, then tighten the locknut back up. You need two wrenches, one for the locknut and one for the stuffing box. All of this only applies if you have a stuffing box. If you are using a PSS dripless seal with a carbon face seal it is not supposed to drip, the disk seals against the carbon and is spring loaded. If this is leaking you need help from someone other than me, you may have a scratch in the carbon or contamination on the disc of some kind. I've never had a PSS seal so am not qualified to offer advice.
