O'Day 27 rudder head
10
Oday 27 Erie, PA
Hello,all.
Having recently put my '76 ODay 27 sloop up for the winter - yes, it does snow in Erie, PA - I removed the tiller and rudder head assembly from the actual (stainless) rudder shaft to try and correct a very sloppy tiller. The original rudder head had a 3/8" bolt pinning it to the rudder shaft, but this hole has enlarged allowing the rudder head and the attached tiller head to move about. (The 3/8" hole in the harder stainless steel rudder shaft still seems true, however.) There is also a 3/8" bolt connecting the rudder and tiller heads, and the holes in the tiller head are also elongated and worn causing still more slop in the tiller.
In a perfect world I'd probably just buy new rudder and tiller heads from my friendly local O'Day dealer, but alas................
Any suggestions? As new parts seem unavailable, I'm considering having the holes welded up and re-drilled to the original 3/8" diam.??
John
Aug 20, 2010
1,399
Oday 27 Oak Orchard
Hello John. I am fortunate that was one problem I haven't encountered. A good deal of the repair method depends on how oversized the holes are. I personally would look at running a reamer through and making a stainless stud to fit. Reamers can be purchased in any size from industrial supply houses. The concern with welding is the possibility of causing the cast aluminum to become brittle.
