I have an 1976 Oday 27. It had a wire to line halyard set up for the main halyard. Sadly, the wire line got kinked a bit and would not allow the mainsail to raise completely. it would stop about a foot short of fully raising.
I opted to replace it, so i purchased three new halyard lines, one for spinaker and the other for the mainsail halyard.
I was hoisted up via a forlift to replace and add the new halyard lines and i noticed that it could not feed through the new halyard line end with the wire line attached. My problem was on the port side forward sheave. Through feel, i was able to determine that there's a small brace-like cover, like a line protector over the port side, forward sheave. I could get the wire through, however not the rope line. What is with the small brace over the sheave? I can see it's intented to protect the line from jumping out of the sheave, but it seems too small of a space to allow anything other than a wireline.
Since my attempt was unsuccessful to get it fixed, I'm going to have the mast taken down so I can quickly replace it this coming thursday. What size of sheaves are on Oday 27's? Are they easy to replace? Can i get ride of that sheave line guard once i remove the masthead from the mast?
Mark
s/v Booty Call
1976 Oday 27
Mark
s/v Booty Call
1976 Oday 27
