O'Day 26 shroud question
8
Oday 26 Dallas, Texas
I recently bought an O'Day 26. It has the french made mast unlike the 25 I once owned. The T Bar swedge fittings on the top of each of the mast shrouds actually slip into a slot approximately 1 1/2 inches long. The seller of the boat advised me that it would be a good idea to place something inside the slit once the T-Bar is inserted. This would prevent the T-Bar from ever "working it's way out of the slit in the mast. (He stuck a piece of rubber hose on his, but that can work it's way out) My question is does anyone have any idea if such a part is made for this, and if so, where can I get some? I will call Rudy at D&R tomorow, but just in case I wanted to throw this question out to the forum. I can easily see that under some loading conditions it would be possible for one of the T-Bar fittings to simply drop out of the slot in the mast...I want something in that slot designed to keep that from happening. Any ideas? Thanks!
Mike
something like the sail stop on the mast
Not sure what that slot looks like but on my 25 and maybe on your old one there is a stop in the track for the main sail. Its about 1 inch square with a grove on each side so that after sail is on you slip it in the track and turn a knob on its face that pushes a large flat screw against the mast and keeps the sail from dropping out of the slot. Then you could remove it if you needed to. Maybe even a screw with a head big enough to slide in the slot and a locking nut to hold it in place. Good luck, Mike
