Oday 26 ground cable.
Nov 1, 2012
108
I'd like to replace the ground cable between the battery and the engine. The current one is sharing a bolt with the engine mount. Have any of you replaced this? If I remove the bolt to replace the cable, am I asking for alignment trouble? Is there another location that you have successfully used for a ground that is easier?
I'm trying to fix an intermittent hard starting issue.
Thanks
Joe
