nothing to luff about
My 81 25 footer points much higher into the wind than the 60 degrees you describe. Further, she performs famously to wind. First, this is a "is it plugged in" question. My boat had some performance problems until I remembered the topping lift. One of those, whack me in the head with the boom things. The sail flattens a bit better now.Second, if there are no other variables to consider as the proper sail size (as they are new) and, when sailing, proper sheet tension/angle, I suspect there may be some mast tuning needed. There are others on this discussion group that can give you more specifics about stay tension than I. I must yield to their expertise.Steve!
