I did a search on the forums and couldn't find anything on this topic. I have leaks and the water runs down the inside of the fiberglass headliner inside the boat dripping all over the starboard side. This makes it very tough to determine exactly where the leak is coming from. I have found several postings on what/how to rebed to stop leaks, but I am in the water and really don't want to mess around rebedding everything if the leak is in an isolated area, I would rather find the leak inside the boat, and the only way I can think to do this is to remove the headliner.
Has anyone ever removed the fiberglass headliner in their Oday? If so, how did you do it? I didn't see any screws or bolts holding it in place - maybe I didn't look close enough. I am hoping it isn't molded into the boat as part of the hull where it would need to be cut out.
Thanks in advance for any thoughts,
Joe
Joe
