This past weekend I found quite a bit of core rot under the mast step. I cut open the top layer of fiberglass and ended up removing a rather large chunk of my cabin roof, from the mast step to both port and starboard handrails. All core in that area was either soaked or rotten.
I was wondering what core material everyone is redoing their cabin top in. Is everyone putting in more balsa with the plywood core at the mast step? Or are they people out there building up the fiberglass layers to the thickness of the rest of the cabin or using foam core?
