C Charly . Jun 8, 2016 2 o'day 240 King George Jun 8, 2016 #1 I want to put my O'day 240 on a boat lift. Need to know how to position the spreaders to the correct size to support the boat. Help
Jackdaw . Nov 8, 2010 11,386 Beneteau First 36.7 & 260 Minneapolis MN & Bayfield WI Jun 8, 2016 #2 Will your lift also support the keel?? If yes make the boards wide for max lateral support. If no you have to be narrow to avoid crushing the hull with the dead weight of the keel.
C Charly . Jun 8, 2016 2 o'day 240 King George Jun 8, 2016 #3 I was not going to support the keel, but maybe I should. Thanks for your ideas. All help is use full in the set up.
