O'day 23 weight?
Apr 8, 2016
18
O'day 23 Kingston, TN
Wow seems they are the same..., never too old or hardheaded to learn sumpin new!!!
Mar 20, 2012
3,983
Is boat displacement the same as the actual boat weight?
Regards and thanx
the displacement weight of the hull is equal to the weight of the volume of water the hull displaces as it floats in the water.... so, yes, by the laws of Archimedes, it is required to be the same;)
what CAN be different, is the "designed" weight of the boat vs, the "actual" weight after you have loaded all your gear in it.... the actual weight is the displacement weight.
