Been there
Alan,I had the same problem with my '83. I unstepped the mast first, which "decompresses" the cabin-top. I removed all of the small screws from the head side of the bulkhead, as well as the chainplates (this gives you a great chance to rebed the chainplates, a common leak point). I then used a small hydrolic jack and 2x4 next to the compression post to slightly lift the cabin top... just enough to slide out the old compression post and damaged bulkhead. These I used to trace the new bulkhead and cut a properly lengthed compression post. I used teak veneered plywood for the bulkhead and stained white pine for the compression post. I soaked the bottom of the compression post and the lower edges of the bulkhead in "GET ROT", a thin epoxy resin, to help ward off future problems. Slide the new pieces into place, lower the jack, and secure with the screws and you're done.I apologize for making this so lengthy, but since you are new to this boat, I have some advice about the chainplates. As I said, this is a prime spot for leakage and damage to the cored deck. While you have the chainplates off, take a bent nail in a drill or some similar device and remove as much of the core around the chainplate opening and screw holes as possible. Force a thickened (peanut butter) epoxy mixture in to the decored areas and clean the chainplate areas with a knife. Redrill the screw holes for the covers. Now the chain plate passes through solid fiberglass rather than balsa core. Rebed the chainplates and covers with 3M 4200 (not 5200!!) or similar polysulfide.I hope this helped. If I can answer any other questions, I check this site almost daily.Good luck, Terry
