Oday 22 scupper
John Settle
The outside ring to the scupper on my Oday 22 sheared off. What replacement scupper will fit this model boat? The inside diameter of the ring is 1 inch and the outside diameter, including flange is 2 and 1/4 inches. Does Oday original equipment require a hose with the scupper? There appears to be a plastic tube inside the drainage, as if the entire thing is plastic with flanges on each end. Also, is the scupper on this model straight, or does it require a scupper with an "elbow?" I can find nothing in the West Marine catalogue that is close. Any suggestions?
john
cockpit drain
John, I went through this with my o'day 22 also. The fixture is just a standard through -hull with a straight nipple.If you refer to Mike Ruth's posting in "ask an O'day owner"--"arrg, where is this water coming from?", there are some good answers.There is a rubber hose the nipple connects to under the cock pit.Good luck and have fun!
Jim Gariepy
Scupper problems???
I think I found what you were talking about. If you can go head first, to the back of the port berth, you well get a good look at this tubing that goes from the cockpit to the stern. It looks like "PVC" to me but I could be wrong. To make sure I would contact the folks at "D&R Enterprises" in Assonet, Ma. There phone number is (508)644-3001. Rudi is a former employee from O'day and aquired a large inventory from them when they closed there doors some years ago. They should be able to help you. Let us know how you make out with this. Fair winds and following seas to you.
