I have my 22' Oday and I have noticed that evertime it rains I find that the inside of the cabin has a few leaks. I have siliconed the ports window frames as well as the glass, but I haven't stopped these leaks. I was going to remove all the chain plates and life line sanctions, seal and replace. In most cases I feel the leaks from the deck are not where I find the water dripping inside as I believe the leaks are running along the fiberglass and dripping at the lowest spot. If that doesn't work I need to know where else to look. Has anyone run into this on their boat and can you give me any suggestions of where to look? The boat will be home for the winter next weekend and I plan to spend as many rainy days as needed sitting inside of the cabin finding the leaks. I need suggestions!
Thanks, Jim
Thanks, Jim
