Diffrent things...
I have a 79 and my electrical panel WAS on the starboard side like yours. I was going to place a radio there, same one you have as a matter of fact, and a new panel. My compass is just above and right behind the panel. I thought about moving the compass, but then decided it would be easier to move then panel to the other side, then to deal with sealing the hole created by moving the compass. The bulkhead turned out to have about a half inch less space inside it on the port side. It seems that the fiberglass is thicker on that side. Now I have to cut some boards so that the switch panels can stand off from the bulkhead. This won't be too bad though, as it will put a nice teak frame around the switch panels. I will probably bevel the edge on it and stain it up to look nice.I just didn't want that much electrical interference with the compass. If I would have thought about it, I probably would have moved it down to the cabinet like Rich has on his earlier model. Not the best place, but the further it is from the compass the better. I'm also moving my batteries from the starboard cockpit box to under the porte sette in the cabin. I purchased a twelve gallon tank to place into the starboard cockpit area, and moved the batteries port to compensate the weight.Much of my wall inside the starbord cockpit area has rotted as well. The previous owner glassed in some new plywood, but now I wish he hadn't. The reason I think it rots is because the water doesn't leave the area under the cockpit to get to the bilge. My cockpit drain did break, and I had to replace it. I put a new brass thruhull so I shouldn't have that problem again. Well, until the other one breaks. This allowed water to pool and rot out the wood. I'd like to get behind the glassed in wall to create a drain to the bilge.In the bilge I'm placing two 1250 gph pumps, and hopefully once everything drains to this area I won't have to worry about any water building up.I'm getting new cushions made, and after looking at your pictures, I can see that mine are original. The apolstry is the exact same. Among other things to do is to replace the hoses for the water as they are moldy, and the water tank for the same reason. It needs lots of work because it had a lot of neglect. The boat was rarely used though, so most of the rigging and equipment is in good shape.Eventually I'll get a digital camera and get some pictures up here...probably after everything is done!Josh
