Oday 22 cleats
Drew
As my niece would say "you make mistake Uncle Drew". I was going to change the cleats which tie off the jib sheets on my 22. I did not see any access to them from the cabin so i mistakenly thought that they had some sort of embedded fatner that the screws went into. Much to my dismay as I lifted the screw from the holes I heard the gentle rattle of something falling into my hull and have no clue where they went. I have lifted the access holes under the cabin seats but nothing was there. How do I rescure these screws? and or change the cleats to cams?
Bob McGee, O'Day 22
I know where they are.
They are in the space between the head liner and the deck. I mounted two cams for my jib sheets a couple of years back on each side just aft of the coachroof. The starboard one went on fairly easily because I could get access for attaching the nuts from the starboard cockpit locker. The port side cam was a bit more of a challenge. I drilled a one inch hole through the head liner above the port quarter berth, hopefully exactly beneath where I had already drilled the holes for the cam. There's about 3 or 4 inches of space between the two liners. After mounting and sealing the cams, I put the nut in a shallow socket head with an extension, fed the socket head through the hole in the head liner and up to the bolt by feel. Once I got a little bite on the bolt, I changed to a deepthroat socket, and with the Admiral holding the bolt head, I tightened the nut. Then I got some of those "hole covers" like the ones covering the nuts on your handrails. Everything seems to work, and it doesn't look too bad.. Bob McGee
Drew
Thanks Bob
If no one elso makes a suggestion then yours will be next on my list of to-do's Thanks
