to Dorian
I used epoxy materials just because I had them. This was overkill because compression is the only force we are dealing with in the deck. Any brand of polyester resin that you can get at any hardware store is sufficient for compression. I replaced my rotted core in the general deck area with marine plywood, but under the mast step (where the loads are high) I put in fiberglass mat saturated with resin instead of wood. I think wood core under the mast step is a mistake, because the wood can crush even if it isn't saturated with water and rotten.The deck is sandwich construction with wood between the fiberglass "skins." You can drill some discreet holes to check the wood and thus determine the boundaries of the repair area. I used a vibrating saw (like the Fein described above)and carefully cut out the area just outside of my non-skid, because I didn't want to mess up the pattern. Once I cut all around, I used a pry bar and blocks of wood to carefully lift the deck skin off, as I wanted to reuse it. It was really stuck down! Once I got it off, I scooped and scraped out the rotten balsa, and let it sit for a couple of days to dry out. the old wood was 1/4" thick, so I got some 1/4" marine ply and cut it up into 2" X 3" pieces. Small pieces are necessary to conform to the curve of the deck. I glued each of these down like a giant puzzle with polyurethane construction adhesive (killer strong stuff). I did not put wood in a big area under the mast step location. Instead I fitted several layers of fiberglass mat (felt) to approach the 1/4" thickness and saturated this area with polyester resin. After that set I disk sanded the whole repair area to fair it in. I then made up a big batch of resin, thickened it with Cabosil (a common thickener), smeared it all over the area and quickly reattached the deck (this was after a lot of test fits!) After this set I filled the saw cut area with polyester filler (I used Bondo) and painted the whole deck. This has worked very well. Hope this helps!
