O'Day 20'Center Board Pin Help
Ruben
Just got my first boat,an 1975 O'Day 20'. Its on a trailer and I want to check and or replace the center board pin before putting her in. I don't know how to go about it.Is there a book or article relevent to an O'Day 20'. Any suggestions or comments are appreciated.
Denny
OD 20 CB Pin
Ruben: The pin is a 1 inch nylon (?) pin located about 1/4 of the way back from the front of the keel shoe. Look for some type of sealant filling the holes about 2/3 of the way up from the bottom of the keel. You can remove the pin by knocking it out with an appropriately sized tool (old screwdriver or cold chisel or piece of rebar) and some sweat. It comes out fairly easy. Replacement pins should be available from Rudy and D & R Marine. Good luck.
Ruben
CB Pin
Thanks, thats exactly what I needed to know. Now if you could just direct me to Rudy and D&R Marine I'd be even more grateful.
Denny
OD 20 CB Pin
Rudy Nickerson D & R Marine, Inc. 14 Water St. P.O. Box 921 Assonet, MA 02702 Telephone (508) 644-3001 Fax (508) 644-3002
