Hello, I bought a 1978 Oday 20 last year. When trying to raise the jib, I found that i could raise it fine, but lowering it was an issue. The halyard would slip to the side of the pulley and get jammed between the block and the mast and not allow you to lower the jib without a lot of trouble. No matter which way I twisted the rope, it didn't help. We lived with it for the end of last season, but now I am trying to figure out what to do before lanching this year.
With the mast down, the pulley spins freely, doesn't have any nicks or cracks and seems perfectly fine. I was planning on replacing it assuming that it should fix the issue. Now that I am looking at pulleys, I am wondering if the line is way too large for the jib halyard. I have to go off of memory since the boat is stored away from my house, but I am pretty sure the jib halyard was thicker than the main halyard and maybe a 3/8" or even 7/16" diameter line. Does anyone know what size the jib halyard should be? It just seems larger than it needs to be.
Thanks.
Thanks.
