Oday 20 center board replacement
Aug 18, 2020
2
o'day 20 lexington, mi
I have damaged my center board and need to replace it.
Any suggestions on how to get started and where I can get a new center board?
The boat is a 1977 Oday 20 and is in good shape otherwise.
Oct 24, 2010
2,405
Hunter 30 Everett, WA
Someone had to build it originally. Failing other options you may look into building one.
Aug 2, 2005
1,155
Hello micheblue and welcome. Craigslist often includes offers to remove old boats under the heading of "boats" or "boat parts". You might try contacting one of those advertisers with a description of what you need and perhaps a picture of the board you have removed. With that idea in mind you should remove the damaged centerboard (if you have not already done that) because perhaps a repair is possible. Check the O'Day owners comments on this site for other suggestions on the subject. Best Wishes.
How damaged is it? If it is fiberglass, it can probably be repaired.
Check with rudder craft. They may have something for you.
