O'day 192 loose stern cleat
rswift
May 17, 2015
8
Oday 192 Saratoga Lake, NY
Upon inspection after winter storage, I noticed that one of the stern cleats is a little loose. It is the starboard side cleat and there is no access to the underside of the screws. I am wondering how this cleat is attached (there are two screws through the top), but I am guessing it is simply screwed into the deck, not through bolted with a plate and nuts on the underside. Who has a plan for the best fix for making sure this cleat is tight and doesn't allow water in? Thank you in advance.
May 24, 2004
7,174
CC 30 South Florida
Not familiar with the O 192 but I would suggest trying to remove one of the bolts; if it just spins it is likely held by a nut but if it comes out it be there is a threaded plate embedded in the fiber glass. Better yet instead of removing just try tightening it. If they tighten then release some added some silicone sealer and retighten.
-na -NA Anywhere USA
Take a picture or two of the cleat on the deck and post them here and I will see if I can figure that out for you but follow Benny's advice first.
crazy dave
