Roger
By an odd stroke of luck, I managed to buy a 150% genoa to fit my O'Day 19 on EBay. It was advertised as being a hank on sail, but, on arrival, I discovered that it has been retrofitted for roller furling, with steel cable and thimbles attached to the luff. I have purchased the Harken Hi Load small boat furling system, which is rated for boats up to 20 feet, and am now wondering what is going to be the best method of installing the roller furling. Namely, should I keep using the forestay (it seems like things might get a bit crowded when I want to furl the entire jib), or should I remove the forestay and use the luff cable and halyard in it's place? Does anyone here have experience setting up roller furling on an O'Day 19, or something with a similar rigging? I would appreciate any wisdom that you can share. Thanks.
