Jason Maranhao
I just bought an old O'Day 15. I'm having a little trouble trying to figure out the main sheeting. The way it's setup is it has a metal bar running the width of the cockpit with line coming off both ends. There is some sort of a slider that runs on this bar to run both ends of the line through. Is this called a traveler?. From there I have no idea how to run the line. There are two blocks on the boom and a block on each side of the boat. In the center there is another block with a camcleat. If anyone has a picture, that would be great! Or if someone can help explain how to run the main sheeting.-ThanksJason
