G
Guest
My '83 OD34 has developed a large 'blister' on one side of the rudder. About 18" high, 10" wide, and bulges out about 1/2". I drilled a hole in it and found the entire fiberglass skin, which is about 3/16" thick, has seperated from the core. It is bone dry - no water in it at all - just a large air pocket. I'm assuming it should be repaired and the repair is to cut it out, re-glass, and re-fair to match the other side.Anyone with a similar problem and how did you repair?Any thoughts on causes?? The rudder was epoxied 10 years ago (Interlux 2000), is blue in color and this is on the side that has always faced south for winter storage and could get pretty warm in the sun.
