Oceanis 42 CC Fridge
henri
Mar 11, 2021
23
Beneteau Oceanis Clipper 42 CC Antwerp
I cannot locate the rotary dial to regulate the temoerature on my fridge. I have a 42CC year 2003> Thank you for your info.
RitSim
Jan 29, 2018
448
Beneteau 411 Branford
The thermostat and sensing bulb is usually in the cold area and visible- unless its been removed by a PO. The thermostat wires should also be visible and connected to the compressor controller. Google your controller for wiring diagram.
JoeDP
Jan 5, 2025
2
beneteau 42 center cockpit Benicia Ca
The refrigerator/freezer on my 2004 42' cc is no longer cooling/freezing. Circuit breaker appears to be operating properly, any advice to possibly determine what may be wrong will be greatly appreciated
Apr 10, 2010
102
Catalina 310 166 Dartmouth, Nova Scotia
Coastal climate control website has a very good section on troubleshooting your fridge/freezer problem. I refer to them often when I or an associate has a fridge problem.
JoeDP
Jan 5, 2025
2
Thank you, I'll give them a try
