Oceanis 400 Gas Cannisters
Dec 28, 2016
37
Beneteau Oceanis 400 Auckland
Hi I'm the new owner of a Oceanis 400, anyone know where the Gas Cannister is kept?
I've found one little one in the Port rear cockpit locker - is that it? I thought that one might just be for the BBQ. Any help appreciated
Nov 8, 2010
11,386
How little is little? Most boats use a 10lb tank; smaller then your home grills 20lb tank
PS - people often use the small camping (1lb) tanks with an adapter when the big tank runs out.
Dec 28, 2016
37
Yes. It looks like a 4kg / 10 lb tank to me, so thats it.
Thank you for the tip about the small camping (1lb) tanks with an adapter when the big tank runs out
Aug 3, 2014
68
CATALINA, BENETEAU OCEANIS 36, 400 Grosse Ile, Mi and Fajardo, PR
Hookway,
Port side behind the wheel you will find a the locker for the in use tank. You will notice a solenoid and propane hose. Port side in front of the in use locker is a second large locker used to store a second not in use tank. The not in use tank is stored in the aft of the locker. All lockers should be insulated where the covers close. You should check the vent is not blocked, it is in the bottom of the lockers. Enjoy your new 400. I have had mine since 2000.
Nick
Beneteau 323 Annapolis MD
[QUOTE="hookway, ...an adapter when the big tank runs out[/QUOTE]
You should be able to find them in the BBQ section of hardware stores.
