Oceanis 38; Calibrating fuel sending unit
Jul 11, 2013
8
Beneteau Oceanis 38 Olympia, WA
Our 2015 Oceanis 38 LCD fuel tank display doesn’t give even a reasonable indication of fuel remaining. First, please know I fully understand these are not intended to provide the kind of accuracy as automotive gauges. That said, when I am at 1/4 tank (by volume), the gauge still reads over 3/4. I have pulled the sending unit and it is tracking / indicating perfectly on its linear scale. The problem seems to be the shape of the fuel tank is quite irregular and so a simple “dip-stick” (sensor design) measures fuel depth, improperly indicating fuel volume. I simply track engine hours and calculate fuel consumption on our extensive cruises, but if this sensor could be “taught” the actual fuel volumes, it would be problem solved! Anyone played with this? Dealer says it can’t be done.
Deleted member 117556
Had this problem for the last 7 years with my Catalina 310 and last summer had to replace the fuel tank. So I thought great now I can get a fuel gauge that works. Brand new tank, brand new sender and it was still way off. Full tank read just over 1/2 on the gauge. Guy who installed the tank said it must be the gauge so I replaced it with the OEM version and guess what? Reads exactly the same with just over 1/2 when the tank is full. I give up and am back to using engine hours.
Bob
Likes: Uppiano
If it’s a VDO monitor I don’t think there’s any calibration capability. The monitor just reads the resistance of the float arm sensor and converts it linearly. We just keep a log of the hour meter when we refill, and assume a burn rate of 0.7 gph.
Jul 11, 2013
8
It is VDO and that is exactly what it is doing; perfect linear reporting. Some simple programming between the sending unit and the VDO could do the job. I don’t know how to build that.
I use .933 g/hr. for our boat.
Now you’re giving me ideas. A little Arduino or some microcontroller like it could read the sensor, translate it to the right level, and control a variable resistor for the panel to read. Sounds like a fun project, if I didn’t already have a plate / workbench full of projects.
Likes: Rick D
Aug 21, 2019
163
Catalina 315 18 Grosse Pointe Park, MI
As a former fuel system engineer in the automotive industry that actually did a great deal of work on fuel gauge calibration, I can tell you that fuel gauges, on automobiles, are notoriously inaccurate. One factor that needs to be accounted for that there is always a certain amount of fuel that is unreachable in the tank. Personally, I assume that amount is one gallon. Another consideration is that boats heel and pitch from wave action etc. This causes the fuel pickup to potentially suck in air when the fuel level is low. I recommend a more conservatism in your estimations when traveling on bumpy water.
To calibrate my fuel gauge, I carefully log my engine hours, and the fuel needed to fill the tank. I do this understanding that each time the tank is "filled" will be somewhat different. Yanmar publishes fuel usage vs. RPMs for its various engines. Hopefully your manufacturer does as well. I can compare this to the calculations I make using my fuel log. This gives me confidence my estimations.
Here is an example:
My fuel tank is 27 gallons, subtracting 1 unreachable gallon is 26 gallons. If it takes 10 gallons to fill my tank, from my last fill, when the gauge reads 1/2, then, 26 - 10 = 16 gallons of usable fuel remain in my tank. According to my log I put 12.5 hours on my engine. I calculate that I used 10 / 12.5 = 0.8 gallons per hour. I cruise at 3000 RPM. The published curve for my engine shows the same fuel usage per hour. This gives me the confidence that I can travel for 16 / 0.8 = 20 hours on flat water or 120 NM at 6 knots when my gauge reads half full. If there are rough conditions, I would half that.
  • Helpful
