removehtml]Can anyone tell me w3hat the halyard for the topping lift diameter size is.ThanksError: Error: expected [/URL], but found [/removehtml] instead[/removehtml]
Mine is 5/16 inch. I wouldn't go any smaller. All it has to do is hold up the weight of the spinnaker pole. Stretch isn't an issue either, so you can save some bucks on the line.
Steve,I read your post again and I may have jumped to a wrong conclusion. When you said "topping lift" I assumed you meant a lift for a spinnaker pole. You may have meant for the boom. My boom topping lift came from the factory at 3/16" diameter. Hope that helps.Agaliha
