Have a 1995 O.351. This year's haul out will be done with a crane & slings. I cannot seem to find any reference to where to position the slings on the hull. Would anyone have this info please? Thank you
Thank you very much Jocker460 that is exactly what we were looking for!Attached are the lifting points for the 351. On mine the trailing edge of the bow strap is just in front of the paddle wheel.
That is a great idea, I do not recall seeing anything that could be used for that in all the stuff that came with the boat... If I knew what I was looking for... I guess it would be some kind of cup that snaps on the paddle wheel?That reminds me. Put your slug in for the knot meter (Paddle wheel) before turning the boat over to the yard.
And remember to pull out again once on the hard and let it dry out. It will trap water inside when you put in the blanking plug in the water.That reminds me. Put your slug in for the knot meter (Paddle wheel) before turning the boat over to the yard.
That's not super cool. The lifting points ASSUME that the lift can adjust the distance between the straps. That system you show cannot. And you you need a bar to not crush the hull. Good places use Travelifts.How do OEM lifting points assume the straps are attached to the crane hook(s)? I use a bar to attach them. What works doesn't line up with the lifting point marks on the boat. The bar takes the strap stress off of the lifeline stanchions too.
What you show is how I expected OEMs to design for. Hopefully the OP has a setup like yours or the factory points will only be a starting point. We don't have that setup but our crane has worked for many, many years and is rated for 12K lbs.That's not super cool. The lifting points ASSUME that the lift can adjust the distance between the straps. That system you show cannot. And you you need a bar to not crush the hull. Good places use Travelifts.
Often the plug is attached to the transducer cable with a key ring. That way its where it needs to be when the paddlewheel is pulled. It can't get lost, and aids in making a quick switch with the boat in the water.If you're looking to find one on-line, technically they are called a transducer blanking plug.
Ok! Now I get it! Thanks!Often the plug is attached to the transducer cable with a key ring. That way its where it needs to be when the paddlewheel is pulled. It can't get lost, and aids in making a quick switch with the boat in the water.
