Help, trying to remove the larger gear(s) from the Lewmar St40's for the jib sheets. The winch is mounted so the removal slots are facing the coaming and I cannot get the larger gear set out of the base housing. I have tried to get the smaller upper gear off the bottom gear by centering in the housing and lifting the smaller gear off, but not enough clearance to get the larger gear free!
Anyone figured this out, short of having to debed the housing from the boat?
