How to select a design for offshore?b
Preparations for blue/green water cruising offshore include crew, strength, stowage, comfort, systems, safety, etcetera. But if we look at design, how can we judge the good ones? How can we understand the risk we take if we select a less stable boat, and make it even less stable by the way we load and equip it?In my navy training, we were told that "the Navy Regs are written in blood." That meant that most of our regulations resulted from the lessons learned when someone died by doing the opposite.For us sailors, these lessons come from the times that storms strike fleets of boats, and some lose crews or the boats itself. Books like Heavy Weather examine the boats that failed, and the survivors. The leading cause of loss of life and or boats is inadequate stability, measured by Angle of Vanishing Stability (AVS) (also called the Limit of Positive Stability.) These conclusions _have_ been exhaustively tested and verified with different hull shapes in test tanks. Other causes include hull strength, failure of safety gear (or failure to use it), and getting the boat broadside to the waves. This last is most often caused by exhaustion of the crew who are sheltered in the cabin while the boat is unable to heave to, or a drogue device is not effectively deployed. Boats that take the waves end on are seldom inverted, although it has happened."Traditional" designs reflected the realities of taking boats to sea interpreted by great designers. Most of the "classic plastic" designs of the 70's reflect these moderate and balanced principles. The Cherubini Hunters are excellent examples, but a number of others can be named. Most of these designs are well suited to offshore sailing. Whether they are strong enough or prepared enough is another question.Starting in the 80's, production boat designers began to alter designs to make them faster in light winds, give them more accommodation room, make them more convenient and easier to sail, and lower their real cost. Some of these changes are just good design for any conditions, but most of them make a boat less likely to survive, and take care of its crew in a severe storm. (Severe storms have occurred almost every where, and at any time. It' true we can choose times when they are (even much) less likely, but most of the storms that caused large numbers of losses were somehow un-seasonal, or unexpected.)The AVS (or the Capsize Screening Formula if AVS is not available) is consistently used by the experts who examine results of these storms to descriminate the survivors from the losses.The AVS _is_ dynamic. It tells us the force the boat is exerting to right itself, or hold itself inverted in the waves and wind. Of course, it doesn't include the impact of waves and wind, or how we load our boats.The waves and wind are the problem, and it is our choice whether we increase or decrease stability with our loading. I've attached an analysis of Henk's variables for an example.So, I would use AVS, hull shape, capsize screen, and analysis by real designers to pick a hull for offshore cruising. And I would want to know the approximate risks I am taking if I choose a less suitable design, or decrease its stability with loading.DavidLady LillieAnalysis of Henk's variations:"The typical cruiser probably carries from 1500 to 5000 pounds in supplies, spares, equipment and toys around." - If these are securely stowed low in the cabin they improve stability, otherwise, they decrease it. "Although you are right that a prudent sailor should tie everything that is heavy down, most of us still have several hatches and floor boards that are at best "lightly secured" and not necessarily able to withstand a violent rollover..." If it moves, it will go to the lowest point of the cabin - this almost always reduces the AVS. "Last time I checked, however, nobody had yet found a way to tie the water or the fuel in the tanks down. Most cruisers carry anywhere from 150 to 500 gallons of that stuff, i.e. anywhere from 1000 to well over 3000 pounds." The problem of liquids is defined by the "free surface area" they have. A full tank low in the hull has no free surface and contributes positively to stability. A partially full tank is slightly less stable, but the effect is limited by the size of the tank, and the net effect is still positive unless the tank breaks loose."Then there are typically anywhere from 2-6 150 pound bodies to fly around between the cabin floor and the coach roof....." Crew on the cabin benches or the windward wide of the boat increase stability. Otherwise they decrease it. For a small cruising crew of two or four, we really don't play much of a role.All of the stuff we mount on the decks and rigging decrease stability when rolling, although they do increase initial resistance to roll forces. Once the boat is heeled at 90 degrees (a knockdown), _all_ of this weight is pulling the boat over towards inverted and holding it there, even if it does slow the rate of roll as it moves through the water.
