Durability/reliability?
I recently had to replace a plastic (marelon) seacock on the head sink. It was a week before our two-week summer cruise when the handle broke off in my hand as I tried to open it. It stayed in the closed position. I had to have the boat hauled and a new shutoff installed. After all was said & done the cost to replace a $50 shutoff was outrageous.A bronze valve was recommended by the yard, but the parts weren't readily available since I was getting ready to shove off in a couple of days. (The valve was available but the bronze thru hull wasn't and would have to be ordered.)In the long run, the bronze shut off was cheaper (the thru hull much more expensive) and most likely more durable/reliable.The trick with marelon is to keep them properly lubricated with a teflon powder in the off season (when hauled) and periodically with a liquid lube when it's in the water.
