Nylon Bushings need help!!
2
Hunter 37.5 Legend West Palm Beach
Hello
I'm in search of nylon bushings for the swept back spreaders. i had the boat demasted and trucked en route they fell out of the spreaders and now i can't find where to get them. their dimensions are 20mm on the outside diameter, 12mm on the inside diameter and 23mm in length.
they came off of a 94 hunter legend 376. i appreciate any feedback where to find these or any alternate ideas or solutions.
thank you
Nov 6, 2006
10,113
A machine shop could turn some out pretty quickly if they have the dimensions.. They could turn one long one and cut several to length from the long one without too much drama..
McMaster-Carr has some that are close, but not correct..
http://www.mcmaster.com/#plain-bushings/=58x76r
A plastic supply house may be able to help too..
Sep 4, 2007
776
Hunter 33.5 Elbow, Saskatchwen, Can.
Who manufactured your mast? You might try Rig-rite or Spar. Spar had the bushing for my mast.
Don
Dec 2, 1999
15,184
Contact Hunter Marine. They can direct you to the vendor that provided the spars for your model. There is a good chance that Seco South was their provider.
