novice sailer
caguy
Sep 22, 2006
4,004
Another solution is to get yourself a storm jib.
Alan
Jun 2, 2004
4,174
Hunter 35.5 LI, NY
Yes, you can reef a headsail. If you don't have roller furling you can add reef points to your hanked on genoa/jib just like on the main.
Jun 9, 2010
8
hunter 22 clarks landing
Thanks to all for the info, I will try all when I go out the next time and I will consider a storm jib
JerryA
Oct 17, 2004
549
Tanzer 29 Jeanneau Design Sandusky Bay, Lake Erie
My friend has a jib with reef points. He bunches up the bottom (actually I think he rolls it)and ties it, and has a cable to go from the reef to the stem. The upper part of the sail stays where it normally is. I'm not sure if that is the best way, but it does work pretty effectively.
JerryA
Alan
Jun 2, 2004
4,174
Hunter 35.5 LI, NY
Jerry you are right, it's not the best way. Your friend would be better off if he moved the sail lower on the headstay instead. The reefed tack should come down to the forestay tack fitting. That moves the CE of the sail lower and produces less heel and weather helm when the wind kicks up.
