I can't find a bow hatch for my 1982, 27ft hunter.The hole is not a true square and the stuff I've been looking at are square.Can you help?Thanks again...tomPS What size bilge pump for replacement do you use?
Does your hatch have a manufacturer name on it? I replaced my H27 side ports and found the original manufacturer via internet. I am in the process of added a bigger bilge pump at the engine compartment as a back up pump. The bilge is so shallow that you can only fit in a really small pump.
