C
Chuck Fort
I am seeking the collective knowledge of everybody here. Returning back from a sailing trip Labor Day weekend, I was not able to get full RPM. Normally I am able to hold 3200-3400 RPM on my Yanmar 1GM in my 1983 Hunter 27 with an appropriately sized 3 blade prop. All the way back (6 hours) the engine would not go above 2700-2900 RPM. When I returned to the marina that day, I cleaned the prop and changed the primary fuel filter hoping that one of them was the problem. Fuel filter was clean, took some wildlife off of the prop. When I went out today, initially the engine would only do 2400-2600, but eventually got up to 2800. The engine will get up to 3200 in reverse and up to 3400 with no load on the engine, but seems to break up a little at the higher RPM. The engine is rated at 6.5 HP at 3400 continuous. During labor day weekend, I ran the engine at anchor at 2000 RPM for 20 minutes twice to charge the batteries. The engine has the stock 35 amp alternator.When I got back to the dock today, I checked the secondary fuel filter (it was clean), rebled everything, checked the air cleaner (clean), took off the mixing elbow to check it for carbon (only had a light dusting), and the diesel fuel is from a reputable source that many of the Chesapeake watermen use. There has been an increasing black smudge on my transom this year. The only things I can think of is that the engine is not getting enough fuel from inadequate pumping, clogged injectors, or injectors that are dribbling. Can anybody else think of anything else to check/try before I call in the expensive Yanmar service experts???Any help would be greatly appreciated.
