NORVANE self-steering wind vane
H
Homero
Ahoy Mates, anyone have any experience or opinions on the Norvane windvane system? Thanks for your time. They are relatively inexpensive but it is not easy to find anything good or bad about this unit on the world wide web. Homero.
H
Homero
I found this on the web
I see I have a lot of views and no posts in response to my querry so far, here is something I found myself on a site dedicated to windvanes ,,,, Re NORVANE Date: Sunday, 14 May 2006, at 8:25 a.m. In Response To: Norvane? (Jeff Serrie) I have a Norvane, and am very happy with it. I've had it 2 years, done about 1200 nm. The strength of solid stainless steel impressed me, as well as generally excellent engineering. I notice wind-shifts more now, as it affects direction on a small lake. Slewing in the troughs of 3 metre waves (out at sea) with a following wind is one issue, but it might be better to bear off or scandalise the mainsail completely. The adjustable counterweight is good, though not adjusted much in practice - I usually keep it in the middle. I had a dinghy bump against the paddle one night and it jumped the teeth of the paddle vis-a-vis the aerofoil. It was possible to push the paddle's gear teeth while re-aligning the aerofoil's teeth - hard to push with the fingers, but possible. All in all, it's strong (i.e. reliable), you could repair any of its parts, and it's well made. If I have weather-helm I ease the main a little, and it helps keep the boat on track.
