Nonsuch 22 outboard size
adrift
Aug 5, 2022
3
Nonsuch 22 Noank
My wife and I are new to this boat. What is the minimum size I can use? I'd prefer lighter which of course means less HP. We sail eastern Long Island Sound and prefer minimum to maximum. Day sailing requires less and that's what we do. Tenth sailboat and I've crossed the ocean three times so I'm familiar with sailing. Many thanks for any advice anyone can offer.
The Nonsuches are kind of heavy for their size, so I would think a motor in the 8-10 hp range would be a good choice. Smaller might not have enough power if things were a bit snotty.
dLj
Mar 23, 2017
4,434
I'd probably put a 10hp outboard on that boat. For what it's worth... Don't really know that's just a guess...
dj
Feb 13, 2014
5
Compac Eclipse Claytor Lake
Congrats on your Nonsuch - I’ve lusted after one as long as I can remember. Unless you’re a weight lifter or have brutish friends, I would not even consider an 8 - 10 hp. They are very heavy and pretty much impossible for mere mortals to mount or remove. The Pacific Seacraft Flicka is comparable weight and came with a 7 hp diesel which was very adequate. Tohatsu makes a 6 hp Sail Pro with a 25 inch shaft - that would likely be adequate for your purpose. No, I don’t sell them. I have made the mistake of buying too large of an engine and would much rather err in the other direction. Happy sailing. Eddie C
Nov 8, 2007
1,594
Eddie’s suggestion of lighter engines would get you in and out of your dock/ramp/mooring. Might be a slow slog driving a becalmed Nonesuch home from a distance.
  • Helpful
Likes: dlochner
Weight is an issue. The Nonsuch was built back in the days of 2 stroke motors which are lighter than 4 stroke motors. A modern 6hp 4 stroke weighs about as much as an old 2 stroke 8 hp. That is a concern with the engine bracket, it should be strong enough to support the extra weight if an 8-10 hp motor is chosen. (The 8 and 10 HP 4 stroke outboards weigh about the same.)
Typically on outboard powered sailboats the outboard is mounted on a spring loaded bracket which reduces weight concerns. Once under sail the bracket is raised and the motor is lifted out of the water. The spring makes this easier to accomplish.
When I had a 2900 pound Tanzer 22 a 6 HP was provided enough power to motor through any chop, current or adverse wind. Based on that, I think a 6hp motor on a 5,000lb Nonsuch 22 would result in an under powered sailboat in many conditions, such as working off a lee shore in a stiff breeze. For that reason I would opt for an 8 HP motor.
Likes: FastOlson
The nonsuch displacement is 5,000lbs. By comparison, the Hunter 26 displacement is 4,600lbs.
I make this comparison because I used to have a H26 and replaced the Honda 9.9 with a Tohatsu 6 sailpro. It was more than enough. The tohatsu has a high thrust prop and is geared for thrust over speed. I could get to hull speed at half throttle on a calm day and pushing a headwind I would sometimes need to go to 2/3 throttle. The sailpro was less noisy than the Honda 9.9, much lighter and burned less gas. The sailpro also had a small alternator which was an added plus but not a deal breaker in the overall analysis.
I guess the specification to noodle on is the 400lb difference between the two boats. Will that make enough difference to warrent a larger OB?
