I would start off with things recently added...
Or things that are easy to depower. Such as radios, stereos, TVs, anything that has a power cord connected to the back of the unit. While doing so, check with you meter at a location you know there should be no voltage present, such as a fuel tank, and ensure your meter is set to DC voltage.After depowering everything that is easy to get to, start with things that are a little more difficult. These would be connections at the distribution system. Then work your way back to the inverter (if you have one), battery switch (remove the path from the switch to the distribution panel), charger (either the AC side or the DC side), then the batteries themselves (one ground at a time).Find the single ground point and ensure it is clean and makes good contact. Look for any device that appears to be grounded some place else other that a common ground point. Look for corrosion build-up points between a (+) and (-) connection. Solar power? Check to see that you are not getting any reverse flow back through the ground. A bad diode could cause that. I'm not sure if that is even possible now adays, but it sure was 20 years ago.Key here is to be methodical in you search. Don't jump from item to item. Find out all the things are are using 12vdc and check each one.Hopefully someone might have other suggestions. Good luck.
