Non-working Adler Barbour Cold Box Unit
Ward H
Nov 7, 2011
3,842
Free for the taking.
This came from my 93 Catalina 30. It wasn't working when I got the boat in 2018 and I did no troubleshooting on it.
I replaced it last year.
Not really interested in shipping it but will consider if it is still sitting around in a month or two. (no time to box it up this month.)
Jan 7, 2011
5,999
Oday 322 East Chicago, IN
Got an air conditioner laying around ;-)
93F in Chicago today.
cheers,
Greg
Apr 5, 2009
3,327
These units are pretty reliable and easy to repair. Mine has quit a couple of times in the past 20 years. Once was caused by my sister spilling a diet Coke inside the evaporator which ate a hole through the aluminium. The other was a leaking schrader valve. I do not get AB parts because they are massivly over priced. I silver solder my connections to avoid leaks at the screw connections.
Likes: Ward H
Jaxn
May 17, 2021
33
O'Day 272 Percy Priest
Do you still have this? And are you willing to box it and ship to Tennessee?
Feb 15, 2022
16
morgan 38 built in 1976 38ft fruit cove florida
Feb 15, 2022
16
Ward H
Nov 7, 2011
3,842
Sorry @lantzalot, I missed your earlier post. Thanks @kappykaplan
Yes, I'm in Barnegat NJ and Yes I still have it. At least I should have. I haven't put eyes on it for a while. Should be in my buddy's shed. I can check on Monday.
Mar 20, 2015
3,305
C&C 30 Mk1 Canada
Is this gone ? My "new" boat only had an ice box. I have automotive AC experience in regards to repairing it or repurposing parts.
Ward H
Nov 7, 2011
3,842
Yea, gone. Should have posted as such.
Sorry
Apr 5, 2009
3,327
If you have the equipment to evacuate and recharge a system and the knowledge to make the tubing connections by soldering or flair joints, you might buy one of these and tear it apart for all of the parts needed. They use the same compressor as all of the "marine" icebox conversion kits.
Likes: Leeward Rail
Mar 20, 2015
3,305
C&C 30 Mk1 Canada
That is what I had been considering. A boat in our marina is using an alpicool freezer/fridge unit that has an LG compressor and nice control with display.
I was thinking to tear one apart and possibly use a evaporator from a dead marine unit instead of fabricating one from the alpicool coils.
716
Oday 30 Anchor Yacht Club, Bristol PA
Automotive ac and miniature Refrigeration units are very very different, the hoses on your gauge manifold alone hold almost the same amount of refrigerant your little refrigeration unit holds and if you try to make the pressures equal to what you saw on an air conditioning unit it will be grossly overcharged and quite possibly damage the compressor
Likes: Leeward Rail
Mar 20, 2015
3,305
C&C 30 Mk1 Canada
Correct and very good points.
Pressure is different for different systems. Anyone trained in refrigeration should understand that.
We had the same problem when many refrigeration techs would hook their hoses up to the commercial ice Makers, and bar fridges we sold. (I did that before I ever touched an automotive AC system)
They would say the gas was low. Surprise... Look at your hoses ! Hehe.
716
R404A I hate ice makers but we worked on many of them and just as many seem to have had pink slime. in the trays, ew!
Likes: Leeward Rail
Apr 5, 2009
3,327
I bought the unit I posted the link to for a freezer on my C30 and it uses R134a. It is correct that a capillary tube unit cannot be charge with gauge pressure. They take a specific volume of gas which in the case of this one is 40g per its spec. That said, I have charged my old Adler Barbour unit many times over the past 24 years and getting it correct is very simple. Evacuate for about 30 minutes to get it dry then add gas until you start to hear the hissing at the capillary tube in the evaporator. Then add gas in a bit at a time until the frost line on the evaporator comes to about 3/4" from the top.
