Johnny Henson
I am restoring an older Catalina 22. All hardware has been removed, and all exterior surfaces are being prepared for painting. What is recommended for finishing the non-skid areas. I have heard that: (1) a mixture of epoxy and polyurethane can be used; (2) a gritty compound can be added to the finish coat; (3) West Marine advertises a "non-skid latex", and this seems that it would work well over the existing surface, but I would like to hear some comments/recommendations from someone who has tried and found a good solution and/or one who can give me a warning NOT to try a particular method. Also can the rub-rail be replaced easily, and should it be puchased from Catalina, or is this a standard "stock" item from a marine supply store?Thanks for your help.
