I'm seeking info/opinions about cons of using a light duty non-marine small propane stove in the cabin. Fuel source would be those small Coleman type propane canisters. Our use would be to warm up pre-made food and heat water for coffee on the occasional overnight at anchor. Because of the low intensity use, I'm reluctant to spend the many hundred's for a marine stove.
Here is an example of an all stainless stove camping stove of the type I'm thinking about.
http://www.rei.com/product/737001
I have read that propane on a boat needs to be used carefully since unlit propane will accumulate dangerously inside the cabin. We are in a temperate climate. The companion way is almost always open and also all the ports on my boat open.
My idea would be to secure the stove in a dedicated area underneath our counter area's removable cutting board. Originally, the boat had a full oven in this area which was removed sometime along the way by a previous owner. I could do the installation in a non-destructive way so that a future owner would be able to install another cooking unit.
Many thanks
Many thanks
