I think GOODOLDBOAT magazine had a recent article on using a heavy duty, fiberglass paint roller extension stick as a light duty whisker pole.Any submission for best use of non marine source part as a replacement or addition on your boat?
Marine,Aviation,medicine...retail plus 30%?
I didn't see that but I was thinking for my Mac this may just work for downwind runs with my little jib.I think GOODOLDBOAT magazine had a recent article on using a heavy duty, fiberglass paint roller extension stick as a light duty whisker pole.
That looks like wood. I wonder if it would work for my stairs instead of the frightfully expensive plasteak? Is the surface fairly non slip?As I have posted before, the rubber flooring at lowes and Home Depot is a nice waterproof floor, cheap and uv resistant.
Stu: would that be Whale Marine?ACE Hardware is my favorite marine store. Tools, in-line and glass fuses, Simple Green, door hardware...the list is endless.
Hey, we've got that in our house! Hadn't thought of using it for the boat! Did you tape/glue it down or is it free floating?As I have posted before, the rubber flooring at lowes and Home Depot is a nice waterproof floor, cheap and uv resistant.
It's got a bit of texture, like real wood, so it's not bad and there's no splinters. The admiral says it's no slipperier than any other linoleum, even when wet we've not slipped. It comes in 3 or 4 different colors now. We've mostly got the cherry, with maple (i think) in the guest bathroom. The pieces basically overlap top & bottom about an inch and they're self adhesive so it goes together quick. Each strip is something like 36" by 7" with the overlap.That looks like wood. I wonder if it would work for my stairs instead of the frightfully expensive plasteak? Is the surface fairly non slip?
Dito + Tractor Supply for chain, ss bolts, ss wire rope, running rigging and marine batteries.Home Depot, Lowes, Ace Hdwe, RV Parts stores & Canadian Tire here in the frozen north country. Tools, floating line, fuses, anti-fouling paint it is a long list.
Another Canadian treasure trove: Princess Auto. Generally a good spot for tools, parts etc, with alot of farm and trade stuff you don't normally see in retail. They have EVERYTHING for fixing /rebuilding trailers. I've bought cheap floating line, and even some knock-off marine jam-cleats.Home Depot, Lowes, Ace Hdwe, RV Parts stores & Canadian Tire here in the frozen north country. Tools, floating line, fuses, anti-fouling paint it is a long list.
