I have a Hunter 33 with a Yanmar 2GM20F diesel and a fixed 3-blade prop. I normally let the shaft free wheel while sailing in accordance with Yanmar's advice. Until lately, the spinning noise has been minimal, but sailing yesterday, the noise appeared much louder as if something is striking the shaft every revolution. I examined the shaft and the gears and everything appears normal from inside the boat. However, while sailing a few weeks ago I had a pretty significant shaft seal leak, so I tightened the packing gland nut 1/4 turn as recommended in the Hunter manual. This stopped the leak, but I have not noticed any shaft seal leakage since (none - no drips). I'm not sure if this is related to the noise problem. I'm planning to have divers examine the shaft and prop to see if there is anything that might account for the noise. I'd like to avoid a haul out if I can for obvious reasons. Any suggestions?
