Noisy floor
Ron
Does any one else have the nuisanse of sqeeking floor in the cabin. seems to be mostly around the steps.Any ideas on how to silence it.
Trevor - SailboatOwners.com
shims or stingers
Hi Ron - I've encountered many a squeaky floor on boats over the years. What you're typically hearing is movement of the boards along the edges. When this happens, friction between the adjacent boards causes a squeaking sound. Boards often are slightly warped (Beneteau is notorious for this). This can be mitigated by placing small shims on corners as necessary. In extreme cases, adding a wood stinger for support on larger boards may be necessary. Take a close look and see where the squeak is coming from to determine the correct course of action. Hope this helps! Trevor
