My boat is a 1987 Catalina30.I have no water making it to the taps however I do have a working pressure pump. It provides good pressure in the water heater. I am able to undo the draincock at the bottom and good pressure comes out. I managed to remove the RV antifreeze and flowed about 30 gallons of water out there and down into the bilge. I did see a lot of crud come out of the bottom the tank. I don't think this was ever drained before. The boat had spent her life in the pacific northwest prior to moving over the mountains. I doubt the water system was drained to the extent i went to.The plumbing diagram shows there is a check valve between the faucets and the pump.A. can someone tell me where to locate the pump? I can hear it but can't see it.It must be somewhere near the fuel & hot water tanks.b. Where is the check valve located? Is there an easy way to access this valve?On the good side, I found out that prairie sailors are good at rigging boats. I joined a club and found lots of expertise. They have to put it all up and take it apart each year so they get lots of practice. Has to make a better sailor out of me too. I replaced the driveshaft packing following instructions and some tips found on this site. Went easy and the boat is afloat. Still...Thanks.Ken
