No water pressure
Joan Gené
I am the owner of the HR.34 number 146 named TEMPURA, and I would like to have advice from you of a problem I have with the water pressure. Few days ago I emptied the tanks because I wanted to sail in a race. And know, when I filled it again I only have a good pressure with the tap of the deck shower. When I open the tap of the deck the pump works properly. Nevertheless I have no water in the tap of the kitchen and in the tap of the bathroom. When I open these taps there is no water and the pump is not working. I imagine that it might be due to the presence of air inside the pipes. If so, how I can take it out. If not, which is the device broken. Thank you very much for your help in advance. Joan Gené Badia
Apr 1, 2007
80
Hunter 34 Nashville TN
Pump problem
When you say the pump is not working do you mean the pump doesn't run or the pump runs and isn't pumping any water? Tom
Joan Gené
The pump do not start
I mean the engine of the pump do not start working. There is no water on the tap. It is fun, because the same pump goes to the deck shower than to the kitchen or bathroom taps.
Joan
Problem solved
I already solved the problem which was simpler than expected. The dirtiness of the bottom of the tank obstructed the filter of the kitchen and bathroom taps.
Apr 1, 2007
80
Glad you found the problem
I was going to say if the pump motor ran and no water you would have an air lock, If the motor didn't even start you have a blockage in the line. Tom
Joan Gené
Thank you for your interest
Thany you for your interest Joan Gené
H
huckert
I had also a problem with presure on a HR 352. The hose may be pinched some place Check that first Best regards Paul
